They're so pretty I had to post a picture or two. BRC forged pistons and total seal rings. 8.5:1 compression, Z32 rods, 1mm overbore should make it closer to 3.1L than 3.0L.
These are made out of 2618 billet aluminum, the same alloy that several thousand HP tractor-pull rigs use. It's more likely that you'd crack a head, blow the gasket and destroy the top ring LONG before damaging one of these pistons.
I got these new, but not from BRC directly. There is a special pricing group buy going on for all Z car owners through BRC to get these at "shop" pricing which is about 20% lower than regular "Racer" pricing. They want 25 people, but I don't know if that's going to happen without a lot more advertisement. If you want shop pricing now instead of finding a place with a tax ID to order them for you, you can get into that deal. Neal at BRC said he would be posting it on more Z forums sometime soon; thank Kevin for getting the ball rolling on that!
