let me chime in with my gray goo since I'm "back" for a while
let me first ask what is it that makes a 4 valve head flow any more than a 2 valve head?
there is no reason a 2 valve head can't flow as much, the valve like anything is an orifice, the bigger the orifice area the more the flow... the total combined area is one factor, the other is the way the air mixes with the fuel, and again there is no reason a 2 valve head can't swirl the air as much as a 4 valve head...
Maxmaxima91 showed perfectly the difference between the E and DE motors, and the simple fact that the HP is higher is because it still breathes at higher rpm, and fuels/times more efficiently, but this is a design issue of the whole system which could be corrected on the earlier motor... the E could have sequential injection, the E could have a split chamber plenum like the z32, the E could have twin exhausts, the E could have had better stock cams....
as pointed out, compare the power graphs, at low rpm the E and DE are very similar in power output, and if you exclude the enhancements and benefits afforded to the later engine (see previous paragraph) we could even see almost identical output... so then the only difference becomes the usable rpm range...
if we then look at the rpm range of a normal car, why does the car idle at X rpm? why does the car redline at X rpm? why does the car have X gears in the transmission?
like I was saying in another thread about why a motorcycle engine isn't well suited to a car, torque... the reason a car idles at a certain rpm is because there is a bare minimum rpm required to keep it from dying, and while engine harmonics and noise along with emissions play a part, the simple answer is to stay running.... at that rpm the car needs to have enough torque to move the mass of the vehicle, cargo and occupants (and possibly anything towed) and it all has to be moved within a certain acceptable acceleration or no one would tolerate it....
therefore an engine with good torque down low will be able to idle lower than an engine with little torque, if the engine only has usable torque beyond a certain rpm then the engine needs to be kept above that rpm no matter how much HP it produces on a dyno
does high-rpm HP then mean much? not really, the number of gears and their ratios will determine how well that usable rpm range is utilized, and at the end of the day the only thing that changes is top speed.... which is kind of irrelevant in north america isn't it?
