I would think the benefit of electromagnetically controlled valves would be the precise timing achievable without the possibility of valve float if both a helper spring and coil were used to retract it... higher rpm and finer afr control in varying conditions (load/throttle/weather)
I wouldn't look at it as a huge rotating mass saver, it will but being as the valvetrain is fairly light, camshafts are already thin, I would stick this in a similar category as an underdrive pulley
maintenance might be another story altogether, sure you'd do away with the timing belt running camshafts but you will need some kind of gear to drive the cas wheel, and who knows how reliable in the long run the valve coils would be, we all know coil packs and solenoids fail for no obvious reason, might even be hard to detect a failing em-valve without a scope
