The radiator is an AFCO 80170N http://www.afcoracing.com/ I just bought Louie's in TX and they are sweet. They make an aluminum shroud and fan for this model that covers the back exactly. Slightly low on power, 1150 cfm but with a good duct system I believe I will be fine.
I am a little concerned about blocking the front of the radiator with the Maxspeed cooler, the radiator surface is only 21 X 13 and as you know, you need air flow through the radiator to exchange the heat. This is why I am looking for the stock 86-89T cooler. Probably when I redo the bottom of my engine raising compression to 10-10.5:1 I'll change the stock NA pump to the turbo pump. My feelings are while it is apart I might as well change it to a new one and have the security of knowing that it is new. It makes no sence to me to rebuild something and use old parts.
What, me worry? It just takes a little time, patience and thought!
Has anyone install transmission oil cooler to '88 5man. gearbox?
My gear box gets few times in summer really hot when cruising in freeway 140-170kmh (87-106mph) for "a while"..
MrwassmanNA2T wrote: don't believe we have an oil pump in our transmissions. Just sloshes around. Maybe you can add a pump to circulate the fluids around.
Hot always flows to cold, unless otherwise acted upon. I am pretty sure that all of the skylines oil coolers can be bolted on to the VG's. My rb uses the same filter as the vg.
Skyline has oil cooler for transmission in stock? I have only seen few aftermarket parts and that packed includes pump also.
Off the topic, but you don't happen to speak like Kimmi Raikkonen?
I've always wondered if all Finnish guys speak like him :lol:
True. Like what i would do for a diff cooler.
So would you need to have the cooler sitting flush or lower than the level of fluid that it is cooling?
Kennedy wrote: Skyline has oil cooler for transmission in stock?
Sorry for the misunderstanding, I meant for the oil cooler. There is a stock oil cooler mounted on the block of rb's. I have an aftermarket one from greddy/grex and it will bolt up to a vg. I am sure they can be found for under the $600 price stated earlier in the thread.
