Why do you need to swap front X-member for NA-T?
  • Why do you need to swap front X-member for NA-T?
    I just picked up a decent 86 NA hardtop for cheap, and it seemed like a PITA to swap the X-member if it is just something I could plasma cut off the NA one or something. I've never done a conversion, but I have 2 turbo parts cars and a crapload of performance parts ready for this thing.
    Also... NA cars are slow as balls. I could never be happy with thing without some sort of serious power adder.
    86 hardtop shell, 93 SC300 engine, 95 soarer bellhousing, 91 supra transmission, 95 Q45 differential hubs and driver's side axle, 1992 300ZX turbo driver side axle and calipers, 2004 350Z Rotors, 87 300ZX front end/hood, 1999 Viper radiator, 1992 Mustang throttle body. Lots of glue and tape to keep it all together.
    I've done the n/a to T swap. I thought the same thing and found out the hard way. Doing the xmember swap is actually VERY easy so long as the engine isn't in the car. You need to swap crossmembers because the driver's side engine mount WILL NOT clear the turbo.
    Here's a few pics of exactly what the problem is.
    this is from the back in an n/a
    and with the turbo crossmember. you'll notice that the motor mount is moved way up.
    you'll also have to modify the stock motor mount so that it clears the oil fitting:
    you can also see the full gallery of my work here
    http://zcarwiki.com/gallery/v/homestar/
    Funny stories!
      oh and this picture helps to demonstrate exactly what the problem is.
      Funny stories!
        StreetFighter wrote: I just picked up a decent 86 NA hardtop for cheap, and it seemed like a PITA to swap the X-member if it is just something I could plasma cut off the NA one or something. I've never done a conversion, but I have 2 turbo parts cars and a crapload of performance parts ready for this thing.
        Now just imagine living at a mile above sea level where the turbo z31's up here are just as fast as the NAz31's down there! :shock:
          homestar wrote: I've done the n/a to T swap. I thought the same thing and found out the hard way. Doing the xmember swap is actually VERY easy so long as the engine isn't in the car. You need to swap crossmembers because the driver's side engine mount WILL NOT clear the turbo.
          just so you know... the oil feed is not a pipe fitting.. i hope you dont plan on running the car like that.
            Swapping the crossmembers with the engine still in the car is not as hard as it looks. I've done it a couple times. Once the front control arms and PS rack are removed, it comes right out. To hold the engine in place, you could place a floor jack under the transmission or place a 4x4 piece of timber over the engine, having it rest on the quarter panels, and strap the engine to the timber.
            2000 Porsche Boxster
            2007 Toyota Yaris
              off topic
              wholly rust batman!!!!
              the sierra club is gay!!!
                thanks. Perfect explanation... I think I might actually make a turbo relocation pipe and use a T4 flange... put the turbo up front.
                    yes, get the correct banjo bolt fitting to be safe
                      excelent info, ive been kicking the idea of the project around as well, my question is, i was thinking about building a custom exhaust manifold and placing the turbo up front, what will the situation be as far as the oil lines are concerned? or should i just go ahead and move them while im at it?
                      85 N/A 300zx (vacuum cleaner)
                      95 BMW 740i (daily driver)
                      85.5 Porsche 944 e-spec (sold and missed)
                      69 Impala 2dr coupe (ehh)
                      89 Crown Vic (frame draggin' ole ladys ride)
                        operationcougar wrote: excelent info, ive been kicking the idea of the project around as well, my question is, i was thinking about building a custom exhaust manifold and placing the turbo up front, what will the situation be as far as the oil lines are concerned? or should i just go ahead and move them while im at it?
                        Move them while you are at it? You would have to move them at that point. You would just need to make sure you kept you turbo well above the inlet, of the oil drain, on the oil pan so gravity can do its job to get the oil out of there. As for the oil supply. you would prolly have to run an earls stainless braided line or somthing to the turbo.
                          oh and for the record, ignore what you see with my oil fittings. That was probably one of the dumbest ideas I've ever had. Once upon a time i got it in my head that with enough hose clamps and cheap pipe fittings, i could get oil to my turbo.
                          It worked, only it leaked about a quart a week. I now have good steel braided lines with AN fittings.
                          Funny stories!
                          • #14
                            So youre running AN fittings completely now instead of the banjo bolts?
                            I was debating doing that with the stock oil cooler setup but didnt know if it would cause any kind of issues due to the smaller passage ways the banjo bolts create for the oil lines...I suppose it wouldnt really cause any problems would it :idea:
                            Who are you to tell me my uninformed opinion is wrong?!?!?
                            • #15
                              bemis wrote: Swapping the crossmembers with the engine still in the car is not as hard as it looks. I've done it a couple times. Once the front control arms and PS rack are removed, it comes right out. To hold the engine in place, you could place a floor jack under the transmission or place a 4x4 piece of timber over the engine, having it rest on the quarter panels, and strap the engine to the timber.
                              I know people do it all the time but the idea of tons of metal dangling over my head by a 4x4 just gives me the creeps.
                              http://www.vgpowered.com
