I went to the junk yard AGAIN to grab the A/C compressor support bracket and belt tensioner bracket off a Pathfinder since I didn't realize that I would need it at the beginning. The results are much more managable.
Here's the differences:
Pathfinder LEFT; Z31 Right
The Pathfinder bracket also doesn't use that little piece of cast iron that bolts in between the lower part of the compressor and the middle of the bracket.
I also cut off the portion that the altenator would bolt to on the Pathfinder.
It's also much easier to get to the valve cover screw that is normally tucked inbetween the A/C bracket and the vavle cover.
Oh, the valve covers are being stripped and then powercoated, if your wondering. And, bigger Mercedes injectors are being cleaned, flowtested and installed. :-)
