a few pics of my det ports i thought i would share i still have to get the little dremel bit to smooth them out fully because th eflap wheels that came in my porting tools are way too big to use in these heads
BLOZ UP.com It is not recommended to confirm proper installation by driving into walls or other barriers as this could cause personal injury or damage to the vehicle.
you know i have gerd about how good these heads flow but the ports in the stock configuration suck.huge casting marks and the throat cut leaves a nasty sharp edge on the short side i have to try and peel one of the head gaskets off of the block so i can scribe it for when i do the chamber work,but that has to wait untill i can find a burette.i dont want to have different volume chambers.
