I have a question, could you relocate the inlet to the top edge ? how is the bumper clearance... or were you planning vertical?
Updated pics of dual pass radiator installed end of thread
I think I see it. Pointed right at your timing marks? What did you mount the bracket to? Mines welded to the motor mount bracket. Not sure if that's a good place. I still don't understand how you got the 60-2 wheel in there. Need to see a picture I guess ops:
I've seen another pic of your engine but I didn't catch any details at the time on who owned it. Very impressive.
jn1cz wrote: I think I see it. Pointed right at your timing marks? What did you mount the bracket to? Mines welded to the motor mount bracket. Not sure if that's a good place. I still don't understand how you got the 60-2 wheel in there. Need to see a picture I guess ops:
GE- I was gonna mount it the same way as the stocker. I was just planning on moving the inlet down about 3.5" I figured this would still be ok because the top of the radiator tank is still below the water neck height on the engine, so I wouldn't think it would put any more strain on the pump that way. Whatcha think? It is going to end up being where the stock air filter inlet was (that metal piece next to the headlight that directs air from the Ebay to the OEM air filter).
Hmm, I kinda like that idea of going on the top edge now I would just have to make a J bend with a 90* on the long leg. Then I could use the stock Hose too! Dammit, I left the radiator at work I wanna go try it now. Shit, actually it would take 4 90*'s to make. Hmmmm. Come out the top then 90* left a few inches then a 90* toward the camera then a 90 down over the core then a 90 back to the stock hose location. That may be too much of a pain.85 Z31 6.0 LSX turbo 766whp/792wtq
Satan - It's about time you told me how much it cost fuktard..hehe.
Seriously bro, that sounds like a bad-ass radiator for the money. I might end up running something similar. It's amazing how amateurs become obcessed with *power* but don't invest enough in cooling.
Keep up the good work postwhore!Ucked Fup!!!
craZed wrote: If you move the inlet down, be sure to put a bleader up top.
Otherwise you'll never get all the air out.
How about the strain on the water pump situation? I dont see it being a problem but input is allways a good idea.85 Z31 6.0 LSX turbo 766whp/792wtq
G-E wrote:
elongated hole at an angle ....
try to make it just about level between the two arrow points, but you could put a bleeder screw on the top edge85 Z31 6.0 LSX turbo 766whp/792wtq
New pics of the radiator installed. Bleeder at the top of the radiator to let the air out. you can see where I had to notch and customize the stock hoses and what not. Pain in the ass but it will be worth it. Look at how thick that bastard is! its also the largest you can fit in the stock location and you still have to pound some shit flat to make it fit right. 27" x 19" is outside dimensions.
XSPower??Lance 'never-ending 88na2t project' Landry
[quote]SATAN wrote:Originally posted by LanceXSPower??
yeah the cheepo ebay intercoolers that work great.Lance 'never-ending 88na2t project' Landry
