if you added more quench area at the opposite side, maybe cresting towards the center more.... you could get a few without interfering with any moving metal or airflow from the valves
but adding to the heads in general will cause a problem with airflow, the DE motors have flatter wider hemispheres to seat the 4 valves, ours are more arched clamshell because the 2 valves bigger and set to one side
and any head welding will require preheating and a torque plate or you're looking at line boring the cam journals
