Just drove to firehawks shop to pick the completed car up. NA2T conversion, new clutch, transmission, whole crap load of other stuff.
Anyway, I just went over to the shop, to hear BAD news.
Car was in the air, and we put it in gear, let out the clutch, and tires didnt move, looked under, driveshaft IS SPINNING, wheels are moving an inch.
Blew the diffrential, I dont know if its planetary, spider or pinion gear related or maybe even bearing failure.
Getting a new diff put in tomorrow.
Now for a couple of things.
We started the car up, timing IS NOT set yet, but 87 turbo ECU of course is being used, and the engine idles fine (misses a little) but when you open up the throttle, and rev the motor up it breaks down BADLY around 2000 rpm's, and anything above that its running PIG RICH, so rich that it doesnt even want to rev up on us.
Fuel temp. sensor is not being used, will this affect anything?
What the frell does the ground wire on the distributor do? its a wire that runs right next to the coil, and goes to what looks like a giant resistor and then the wiring harness, what is this for?
We just put in a new speedometer cable while the cars in the air and we take out the clutch the speedometer is reading probably 10 TIMES the actual speed. If were spinning driveshaft going 10mph its reading 100mph and so forth... Remember we switched from a FS5W71C to a FS5R90A (T-5), are the pinion gear teeth diffrent from eachother where it connects to the actual transmission? Firehawk told me its probably the cluster...?
Were running open downpipe (right before the cat its dumped off) and I noticed a little bit of smoke smells like exhaust coming from the turbo area? We dont know exactly where its coming from but we think its just the exhaust coming up in to the engine bay? Will update on this subject at a later date?
Other than those issues if I didnt forget any the swap is going EXCELLENT!!! He did an AMAZING job with everything!
I highly recomend this guy to anyone in the DFW area to try him out!
Absolutely NOTHING was half assed, he even popped out a couple of dents off the body for free!
(86NA swapped to 87Turbo ECU & Injectors using stock T-3)
