i think i have a boost leak because when i was done with my swap and i drove it the car ran nice and it pulled hella hard so i know it was boostin the only problem was a bad radiator and it was overheating but i replaced the radiator,so i drove it alot for awhile before it would start to overheat so i used up alot of gas and had no money to get more,so oneday im drivin with almost no gas then i pull through 1st hit 2nd i pull about up to 3800 rpms and then she starts spudderin and hesitatin.
so i thought i was low on gas so i finally put more in but it still hesitates and at idle its not smooth anymore when i rev it and i can kinda hear air comin out somewhere under the tb,i was thinkin maybe the car was runnin off all the dirty fuel that was probably at the bottom of the tank and maybe i clogged up the fuel filter idk so what you think man thanks for ur time to
