COOLANT HOSE ON TOP OF THERMOSTAT HOUSING
  • COOLANT HOSE ON TOP OF THERMOSTAT HOUSING
    I either keep getting bad hoses or the car is running too hot but I got stuck at hardees this morning b/c my hose over top of the thermostat housing burst again.
    Are you guys still using the stock hose from nissan? anyone know of a stronger replacement you can recommend that I can checkout while im at work today and am waiting on the tow truck HA!!!!!!
    Who are you to tell me my uninformed opinion is wrong?!?!?
    Blocked up overflow?
    http://youtube.com/c/zcartube
      I've used em from Nissan, Gates, and whoever Napa uses. So far I've never had one burst.
        300zxt wrote: Blocked up overflow?
        I dont think so, but I will check when I get it home tonight. It was empty, I just did a flush like.....3 weeks ago and I checked all the lines. It was fine. Strange................
          Coolant bypass hose... had the stock one burst. Got from napa and cut to shape, replacement was a pain to get it on right w/o removing the lower intake, but in the 4 years since then I've had no issues.
            im having the same problem,the hose that goes from the water neck to the thermo housing leaks on both ends,when i looked at the opening on the water neck side it looked like the water neck was cracked,its gonna be real fun replacin that bitch damn
            87 2by2 na2turbo,AE shell comin soon
              i still have the original on mine. :lol:
              the sierra club is gay!!!
                Hmmm........weird.
                  ^^ Your sig is REALLLLLLLLY big.
                  Stock from 85 on mine as well
                    87-85turbo wrote: ,its gonna be real fun replacin that bitch damn
                    It'd be as hard as changing your thermostat.
                    imagination is a virtue
                      I have never had a bad hose, and I only use nissan hoses there. If you keep busting them, you might be damaging them when you install them. I normally replace them during a timing belt service if it looks old.
                      Chuck Stong
                      http://www.300-plus.com
                        MrwassmanNA2T wrote: ^^ Your sig is REALLLLLLLLY big.
                        Thats what a lot of women tell me :lol:
