Lightning TB (twin 54mm)
Relocated Radiator cap and water neck
Large volume plenum
86 hardtop shell, 93 SC300 engine, 95 soarer bellhousing, 91 supra transmission, 95 Q45 differential hubs and driver's side axle, 1992 300ZX turbo driver side axle and calipers, 2004 350Z Rotors, 87 300ZX front end/hood, 1999 Viper radiator, 1992 Mustang throttle body. Lots of glue and tape to keep it all together.
no, not seperated... but there is an airfoil that reduces turbulence and the runners are bellmouthed. It should work OK, I just needed room for my new fuel rails and injectors (Ross machine racing rails and 600cc injectors)
VERY NICE! Are you porting all of these lower intake manifolds that you are welding the plenums to? I would hope so considering the amount of work that goes into making a plenum like that would not benifit all that it could without a properly ported lower intake. BUT, then again you are pumping these things out so quickly I cant see how you could possibly be taking the time to port them as well. :?
Either way, at least it looks very very sexy!
