that pic is of my cam that snapped although the tension on that belt was in spec to from what i remeber so... it happened on the same side on my motor to
An extra 5 mins to get the head off and $15 for a gasket?
Hahaha, good one.
I wish pullin a bone stock upper, lower intake and an exhaust manifold
were that easy. Jacken the motor up aint nothing.
I'd do a leak down test first. If that goes well then swap in another cam.
Maybe you didn't fully understand the entire post. From the point where you can swap a cam (upper intake off, valve covers off, rocker shafts loose) it is 5 minutes to get the head off, slap a new gasket on, and put the head back on. Now I'm sure he is like most of us, pull a head and you're going to check each piston, valve, and combustion chamber. Then stand there and look at it a few minutes more. Then MAYBE start thinking about putting it back on.
I understand that getting the exhuast manifold off can be very time consuming. Especially since every bolt is rusted up. But I pulled a set of heads today where the bolts were all free and it took about 5 mins from the point of discussion.
My point of the post was that it isn't a major undertaking to go that last step further. Especially since you dont know if there has been damage. And those few minutes it takes to verify are well worth spending.
I understand that getting the exhaust manifold off can be very time consuming. Especially since every bolt is rusted up. But I pulled a set of heads today where the bolts were all free and it took about 5 mins from the point of discussion.
You needn't have to pull any manifold off to get at the right side camshaft. Tearing down to the short block can be a PITA for a first timer.
I've heard it is possible to get the left rocker cover off w/out pulling the upper as well, but I have yet to see that.
I may be mistaken, but I thought a leak down test would confirm any valve damage? It makes sense to me that if that test reveals good valve sealing, then it is most likely you wouldn't have to dismantle the longblock.
Low mile OEM headgasket > $15 new gasket anyday.
Whatever, if it were my motor I would pull the heads for an excuse to port them.
Ok, sorta skimmed through this thread, gathered this...
You broke your cam, now you want to pull a set of heads off of an NA and use ONE of those cams?
A. dont use NA cams on a turbo car if you can help it. Longer exhaust durration with increased exhaust overlap due to a lower lobe sepperation angle.
B. DEFFINATLY DONT USE ONLY 1 NA CAM. This will throw your volumectic efficiency out of balance on each bank.
C. You have people telling you to use a stock VG33 head gasket because it is cheaper. DONT do that. The VG33 has a larger bore so the gasket on each cylinder has a wider diameter wich will end up lowering compression on a stock vg30 block. Not to mention what other problems that are beyond my knowledge of qwenching in the cylinder area. If you were doing it on BOTH sides I still wouldnt do it due to the fact that it being larger would create undesired turbulence while compressing the air fuel mixture.
D. NEVER reuse a headgasket. Unless it was designed to do so like a copper gasket. The nissan gaskets ARE NOT designed for it.
E. Pulling a head of takes WAY longer than 5 minutes, I dont care WHO you are and how your z31 is set up or how rust free the bolts are!
This is just my advice, follow it if you want.
Whoa. If that is what it seems that I meant, it isn't. My bad, I guess.
I meant that a 57k mile oem headgasket has more life in it than a
0 mile felpro or the like. Not worth tearing down and replacing just to have new gaskets.
If the head has to come off then replace the gasket with a VR or a nissan gasket, not some cheap replacement.
