I have done some searching, but I just want to make sure. I am going to buy some other things before I get a turbo upgrade (exhaust, intake, IC, fuel pump, injectors, etc).. i just wanted to make sure I am correct when I buy it.
Turbo:
http://www.blaastperformance.com/index.php?p=t3t04e-60
This is direct bolt on, correct? Has the 4 bolt inlet with the 7 bolt outlet (thats what they mean with t3/t04e?)...
And I would need an external wastegate.. which i'll research asap... i just want to make sure i'm getting all this - I want to know i do things right. I read the howstuffworks.com section on turbochargers to get a better grasp on everything.. it helped, but some stuff I was left in the dark
anyways, any help is appreciated
Turbo:
