doubt with fuell pump.
  • doubt with fuell pump.
    hello I have a doubt, with the fuell pump of z32 would have enough to feed for 600hp?
    You'd be pushing it. I would just go with either an Aeromotive A1000 or a dual Walbro setup.
    If you're really pushing that much, then you might as well sump the tank, install some nice braided hose, and mount the A1000 on the frame.
    1987 300ZX Turbo - http://www.z31performance.com/forum/vie ... php?t=3114
      Are you talking 600whp? OR 600 crank HP? NO WAY would it do 600whp. 600 crank like Evil Z31 said is pushing it.
        How will the walbro 255 be at 600 to the ground?
          87-85turbo wrote: How will the walbro 255 be at 600 to the ground?
          I dont think it will do it. I had it pushing about 500whp but I'm sure that was its limit and I wouldnt want to find out how much more it could do just for fear that I would melt my engine at that hp level if it couldnt keep up. :shock:
            So what pump are you gonna go with to reach that 850hp you want satan?
              87-85turbo wrote: So what pump are you gonna go with to reach that 850hp you want satan?
              I run twin walbros
                damn that looks real easy to install hahhahaahahaha
                  SATAN wrote: Are you talking 600whp? OR 600 crank HP? NO WAY would it do 600whp. 600 crank like Evil Z31 said is pushing it.
                  Satan at the moment I am buying pieces and mounting in the car, but attempt not to have to buy twice, desire is to arrive until 600hp but not to where it will arrive, then you advise to me to put two pumps one for each incline of injectors? the injectors are of 800cc. ok?
                  you pardon if it is not understood but I translate it with the translator.
                    It would be easier if you went with a sump and Aeromotive A1000.
                    Sump kit: http://store.summitracing.com/partdetai ... toview=sku
                    Aeromotive A1000: http://store.summitracing.com/partdetai ... toview=sku
                      that a1000 is nice but im sure its not just a easy dropin procedure is it?
                        Neither is a dual pump setup.
                        The A1000 just mounts on your frame, and you run an AN line from the tank to the pump.
                        It's actually quite easy. If you can build a car to hit 600whp, then you can wire in the pump to support it.
                          Well im at 750whp right now and im runnin the stock pump and its doin fine,so i think ill just keep the stock one
                            HAHAHAHAHAHA im fuckin with you man,im not even passed the 250 mark yet,but you think i can support about 420 reliably with a walbro?
                              87-85turbo wrote: HAHAHAHAHAHA im fuckin with you man,im not even passed the 250 mark yet,but you think i can support about 420 reliably with a walbro?
                              Yes.
