I am going to be swaping out my injectors tomarrow and had a couple of questions. Do the new seals go in dry or do you use something to lube them before install. What has to be done to put dual/side feed injectors and rails on an 86 with top feed injectors.
Thanks Andrew
Thanks Andrew
