I finally have a spare set of heads ready for porting and a valve job etc. I would like the best flow possible - the are most likely going on a 3.3L high compression NA, but i may stay w/ 3.0. I'm figuring on using stage 3 Schneider cams. before you type anything, know that this is in a pre-smog 2,200 lb 510. I have budgeted about 1k for the heads- hopefully including cams and springs, ferrera valves and port work. that might be too much to ask for though. to whom should i send these heads? your opinions please...
just a sidebar, the turbo early (A) heads have pretty nice intake ports already. the exh sucks of course.
