thought it was half price weekend, but read the ad wrong, doh. Either way there were a ton of "new" wrecked maxima's with the dual throttle plate, power-valve, variable geometry intakes, and some maximas with the z31 like plenum only with the throttle body in front (or on the back, depending on how you mount it).
The dual throttle plate one had a nice, clean stepper motor idle control which I'll probably try to use with MS.
So now I have a "complete" engine, I just need all the parts that move inside of it, like pistons, rods, crank, cams, etc, etc.
I think I'll be running the dual throttle plate one, even though it feeds from the side, which will be annoying to plumb.
