Wastegate is currently removed and just sitting on the flange. I did this because when i originally reassembled the engine, I never took any time to properly finish the inside of the pipes where they are welded together.
Whats not pictures is the heat shield that I made to protect the valve cover gasket and powdercoat from the heat off the wastegate.
Gate is a HKS 40MM with a 14.7psi spring. External dump currently however im thinking of possibly making it dump back into the exhaust when I reinstall the engine again. Not sure if it clears the factory intake manifold as I'm using a custom manifold with forward facing throttlebody.
