I am not seeing any issues with your methodology here and the numbers make sense to me... for what that is worth...:shock:
I hate to say it but I am going to stick with my initial impression even after reading the other posts. I think you may have a grind issue man.
I would triple check the cam gears and overall install and to some extent start from scratch just to verify that you have repeatable results. It will be a bit of a pain but if you can start back from the start, leave the cams in, and go from there again you may find something you may have done the first time around. Somewhat unlikely given you experience, but it could be worth the effort.
Can you take the cams to a local shop and have them verify the durations? I would think that a good shop could do this for you.
