I have installed a t4/t3 turbo, t4 intake side and a stock t3 exhust side, big sperco intercooler, 2 1/2 intercooler piping. I can only make 14 lbs boost. I was thinking its a bad electric boost controller. I pulled off the vacuum line going to the turbo boost controller on the turbo, still 14 lbs boost. its a modified stock t-3 turbo, maby thats all I get ???.
low boost pressure
LOW BOOST
I JUST LOOKED AT THE STOCK T-3, THE ACTUATOR ROD HAS APX 1/4 INCH OF COMPRESSION ON THE WAST GATE HOLDING PRESSURE TO KEEP IT CLOSED. MAY NEW SET UP HAS NO EXTRA FORCE ON THE VALVE. I CAN SLIP THE ACTUATOR ROD ON AND OFF OF THE WASTE GATE WITH EASE, UNLIKE THE STOCK ON, HAVING TO PUSH THE ROD IN APX 14 INCH TO HOLD TENSION ON THE WASTE GATE.
LOUD............. NOISES!!!!!!!86 hardtop shell, 93 SC300 engine, 95 soarer bellhousing, 91 supra transmission, 95 Q45 differential hubs and driver's side axle, 1992 300ZX turbo driver side axle and calipers, 2004 350Z Rotors, 87 300ZX front end/hood, 1999 Viper radiator, 1992 Mustang throttle body. Lots of glue and tape to keep it all together.
