I have installed my HX35 and everything works very well, but I cannot control the boost on it at all. I first thought it might be because my wastegate actuator was not opening the wastegate enough, but I took these pictures comparing how far it opens with the stock flange with the 3"vband outlet and how far it opens with my bellmouthish downpipe. It seems to open further with my downpipe, but I still cannot stop the turbo from boosting. I took an air compressor and stuck it on the vacuum line that runs from the manifold to my wastegate actuator to verify that the actuator was still in good working order, and it was. Does anyone have any idea why my boost isnt stopping at the stock level with the stock actuator? Or better yet, why it isnt stopping at all? Is there something right in front of my face that I am missing? Its a simple mechanism and I cannot understand what is failing....
edit: I have had the vacuum line coming from the compressor housing and coming from the intake manifold, if that matters.
EDIT II: Pretty sure its a leaky diaphram, I will let you know when I get a new one.
closed:
stock:
my bellmouthish downpipe:
closed:
stock:
