im doing a turbo conversion on my 89 na in a few weeks. im using a stock t3 and with stock heads. im replacing my cams with jwt s2's. about how much power do you thing i would make with this setup at 8 psi.
na2t hp
Well since a stock turbo makes 200/205 at 6.5psi. I would guess add a couple hp for higher compression and a couple for the extra 1.5 psi. I'd say assuming everything is right with the car you will have 215-220. Huge gain from your current 160ish I guess.
on a new motor (rebuilt) 9:1 compression, with e-fan (was turned "on" during the dyno run), no exhaust (open downpipe), Cone Filter, and stock charge pipe plumbing on stock boost I made 214RWHP and 243RWTQ...
just to give u an idea...1SIKZ31 -86 SlickTop- R.I.P. 03/01/10 ... Parted out :-(
... New Project: LS1 Miata. Complete. 510whp. 2500lbs.
