pulling the engine this weekend
  • pulling the engine this weekend
    well I guess I will start on the engine rebuild this weekend sometime. so Im gonna pull he engine with a few friends. any advise? Im sure one of us will be bleeding by the time the weekend is over.
    1989 240sx rb20(daily driver)
    Just pull it slowly and keep checking for clearence and wires/ hoses
    that may still be atached.
    Have rags,beer and a camera on hand.
    Oh yea, get used to it :wink:
    Probably wont be the last time.
    Also, if you are in charge, make sure you have all your "helpers"
    show and tell you all that they removed and were it goes.
    Have a bucket of gas to toss the nuts and bolts in (keeps them clean).
    Have plenty of brake parts cleaner on hand.Spay it into every bolt hole on the block to get all the trash out.Use it to clean the heads out good before instalation,because oil can and will drip on to the new head gaskets as you are setting them on the block.
    Put a length of fuel line on the rod studs as you are inserting them
    into the block and on the crank.
    Plasigage all bearings per FSM.
    Folow FSM!
    Good luck!
    imagination is a virtue
      Be sure to drain all fluids completely before pulling it. I always "forget" to drain the coolant from the block itself and it ends up all over the ground.
      Also, gear oil is not your friend either. Drain it, and be sure the DS is back in before you fill the trans if you fill it from the shifter like I do *DOH*
      Remember to disconnect the little stuff like oil pressure sending unit, I always forget that little jerk.
        i don't like the idea of a bucket of gas. In every single safety video is says to never use gas as a cleaner. simple green is non flammable.
          no worries, with my friends, I think ill be staying away from a bucket of gas. I can just see one of them finding some way to blow that up.
          as for connectors and such, I find that using masking tape and numbering things always helps me put stuff back together faster
            liquid gasoline burns
            gasoline vapour in a confined environment with air explodes
            I have managed to set a drum of hot diesel on fire in a quarry ... strangest thing to see
              didnt mean that literally, just meant im sure something stupid would happen. what did it look like?
                heh it doesn't look like fire at all.... like individual dancing flames popping up randomly around the edges of the drum
                basically the opposite of a wood fire
                I'm sure watching fire in zero-g would be awesome too
                  G-E wrote: heh it doesn't look like fire at all.... like individual dancing flames popping up randomly around the edges of the drum
                  perfect circle if i remember correctly
