man you guys are getting hosed on machine work.the shop i use dosent charge for cleaning the block if you have machine work done there.owner says it has to be done before it goes on his machines anyway.i had a 302 bored .030 over cam bearings and freze plugs installed for 125 bux.also had heads done there cleaned spring pressures checkes 3 new guides installed and valves lapped for 100.friend of mine is building a 289 for his mud toy and the place he is getting to ballance the bottom end is only charging him 200 for that.
Anyone who has had a block prepped...
balancing 220, (including everything that spins, clutch harm balanc.) this is all within +/- 1gram
bore and hone 12 a hole,
hot tank 30
check line bore 30
and if I couldnt get these prices where I did the guy pretty much next door could do it, or the guy next to him, so on and so on85 Z31 6.0 LSX turbo 766whp/792wtq
roastin300 wrote: thats really cheap steve. it would be alot more here. Assembling my bottom end runs around $300 without parts he said. hot tanking it is $50, boring is $40 a hole and i think $8-12 to hone it each. balancing is around $200.
That and you should build your own bottom end and save 300. put that 300 toward a nice tourqe wrench.85 Z31 6.0 LSX turbo 766whp/792wtq
This is the price i got .
Hot tanked $50
Bored & honed $120
Deck Block $80
Internally Balance to +/- 1gm $150
Polish Clank $35
Total $435 :wink:1988 SS TURBO BEING RESTORE.
Re: The prices I paid this past January
[quote]Jason84NA2T wrote:Originally posted by Alex86na2tBlock
1.Hot vat
2.Bored and honed (.089 overbore)
3.Knivecut counterweight balancing (with all rotating assembly, from crank pulley to entire clutch)
4.Assembled until oil pump &rear main seal (oil pan left off)
$400
Heads
1.Hot vat
2.Beadblasting
3.Valvespring disassembly
4.Backcuting valves
5.Resurfacing both heads
6.Valveseat grind
$270Originally posted by Alex86na2t[/list]
Holy crap, that's one heck of a deal on both!
.089 overbore???? that's more than 2MM! so it will be between 3.2 and 3.3L in the end. Planning to use VG33 headgaskets?85 Turbo Slick Top
canada is worse, cars are not considered well loved pets, in fact even the rebuilders only seem to care about ripping people off that are stupid enough to rebuild
but then the counter balance is the wrecker network and reman parts supply is fantastic and fairly cheap
Alex86na2t wrote:Holy crap, that's one heck of a deal on both!
.089 overbore???? that's more than 2MM! so it will be between 3.2 and 3.3L in the end. Planning to use VG33 headgaskets?[Chuck Stong
http://www.300-plus.com
