CAS
  • CAS
    hi there fellas
    im on the look for a Crank Angle Sensor but im finding nothing online!
    the best my nissan dealership can do is get me an 800$ distributor to replace my broken CAS!
    does anyone know where i can order one of these up!
    thanks
    http://www.youtube.com/user/onefast87
    junk yard
    imagination is a virtue
      onefast87 wrote: hi there fellas
      thanks
      Are you sure it's broken?
      BLOZ UP.com
        thanks
        I hope you get a massage and some beers after they rape you
          lame...
            Is the 84 NA the same? because i might be able to get you one of those.
            eagle rods
            38 mm external wastegate
            mild port/polish
            3 angle valve job
            custom intercooler piping
            rad moved back
            romulator
            420cc injectors
              the most I've ever paid for a whole used dist was $50 and that was an almost new cap and all the plug wires with it... and it worked fine
              I picked up a pathy dist with a brand new cap (swapped from a quest) for $10 as well
              so consider that the general range of fair
                right on! I will ask him if he will sell it for $50. (I don't know if he will -- he tends to collect cars, I think he has 60 cars in his yard right now)
                eagle rods
                mild port/polish
                3 angle valve job
                rad moved back
                romulator
                420cc injectors
                  I talked to my buddy.. and he's trying to get another parts car right now and then he will consider parting out the dizzy -- but he thinks it might be pooched anyhow... so i'll have to check to ensure the cas is okay.
                  eagle rods
                  mild port/polish
                  3 angle valve job
                  rad moved back
                  romulator
                  420cc injectors
                    THANKS for the help guys but i found a website that sells them!
                    http://www.net-parts-express.com/
                    75$ is alot cheaper than an 800$ distributor!
