Injector install - need quick advice
  • Injector install - need quick advice
    Hi guys,
    i am now typing with hands full of oil because i just interrupted my injector swap on half way. The stock injector plugs (mercedes injectors) do not fit to the injectors. How did you solve that problem? Getting other plugs? Or is there a trick to make them fit?
    Dino
    yes your suposed to take off a little bit of plastic of the injectors until the plugs fit snug.. cut it off whatever..
      Just cut down the factory harness connectors a little, not the injector's plug. I didn't even need to shave them but 1MM, then put some RTV in by the seal and they will stay snugly in place.
        aha, good advice.
        Unfortunately we could not finish the work because my friend, who owns the garage wanted to go home and watch the soccer-game ´sweden against germany´.
        So i can try to get the right plugs on monday, and if not i will go for the ´shave the harness plug´ solution.
        Aaaargh, i was so keen on tuning the bins tomorrow !!!
        But, on the other hand i will find the time to prepare a little GT3271-Installation-story with photos for you.
        Dino
          germany won 2-0 both in the first 15 mins of the game . great game....
