nice. i wonder if it would have the same effects on the Z. someone try it out.
MAF after turbo?
in which case.. i might try it... the piping volume i have causes a very lean situation when i first step on the throttle.8.5 custom arias pistons (.020 over)
eagle rods
38 mm external wastegate
mild port/polish
3 angle valve job
custom intercooler piping
rad moved back
romulator
420cc injectors
i'd find an extra working MAF or two before you do it
yeah.. you're right.. i think i'll wait.. i just don't like seeing afrs as high as 17 when i first open the throttle... could be dangerous...8.5 custom arias pistons (.020 over)
eagle rods
mild port/polish
3 angle valve job
rad moved back
romulator
420cc injectors
