92PathSE wrote: I was really hoping to make over 200 whp on my NA, but after reading this thread maybe not. My VG30 spare(pathfinder) has about 15k miles on it so I don't want to replace anything in the bottom. I was just going to port the heads, change cams, and use a larger TB from a 240SX sohc or change out the whole manifold to one from a VG33, if that's possible. Megasquirt for fuel and spark. I'd be really happy with 150 on the pavement but I don't see it happening now.
There's no room for a turbo and IC where they won't get damaged by rocks and stuff. Plus there would be miles of pipe.
Thanks for the info :-D
Got to 164 and 170 in two different cars with this set up and adjustable cam gears.
I ported/polished the heads and added nismo cams, and 260cc injectors looking for 200.
Unfortunately, the # 5 rod bearing gave out last summer (had 206K on it ) so I am starting over.
The bottom end is done, but the heads I had hoped to swap over were ruined also.
The new bottom end has The 12:1 CR Ross pistons. Once the new heads are done, I have no doubt that this time I will surpass 200 WHP. Hopefully that will be this summer before the race season is over.
