G-E wrote: a "simple" system exists on my k-car.... there's a vac line infront of the throttle body, same as the Z... but there's no solenoid "off switch" so it's always opening when there's sufficient vacuum.... (it's a flapper door much like the heater core door)
and I can tell you having tested different types of intake, including ram air, that the k-car ecu is definately not tuned to deal with a higher efficiency intake, the car doesn't ping or anything but it becomes gruff and feels like it's breaking up, but as the timing is 8 degrees stock on 9.5:1 that could be cured with added timing and 94 octane.... still not much point
the ram air made a huge difference when flooring it at highway velocity, I could actually pass reasonably quickly (read: less than eternity), but the moment I let off and start cruising is would get choppy, touch the gas and everything back to normal except for the unwanted acceleration
in both cases, the Z and the K don't activate the egr idle, the throttle is closed and the vacuum port is outside, only light throttle will create vacuum on the Z and lets say due to the restrictive intake design the K suffers from more vacuum at greater throttle positions
I know how the car breathes, it's almost like a turbo, I have to close it to get some engine vacuum going and pop it open to increase VE to get anywhere, but steady state running will trigger the egr and it can't turn it off..... the Z can
Ive also noticed some slight inconsistency, but hardly noticeable to most, in the lower rpm range (below 2500) when cruising in town below about 40 mph. I often suspected vacuum leaks but Ive exhausted those possibilities and reserved myself to the EGR without a good reason why before now. :?
Anyhow, interesting stuff. Much appreciated here. 8)
