So apparently I'm making a bit more power than I realized and I burned up the stock fuel pumpl. Fortunately, I knew this was only a matter of time so I already had the Walbro handy. Well, I'm pretty driven to finish this before I go to bed tonight and I've already dropped the tank and pulled the pump, but before I put the Walbro in, I'm reading that it has to be inserted a certain way so that it will fit into the baffles? I guess I'm incompetent because the picture doesn't do this justice in the writeup found http://www.redz31.com/images/fuel/FuelPumpInstall.jpg
Need a bit of help with the Walbro 255 Fuel Pump install
Ugh....how disheartening. I guess my fuel pump wasn't burned up afterall because even after installing the Walbro, I still don't have anything. Fuse is good, I've already checked that. I'm thinking it could be the relay. I guess I'm going to hit that up and then hit the sack if that's not it. I'm lost as to what else it could be.
*EDIT* Well, I'm totally lost. It wasn't the relay either. What else could cause this?Originally posted by Andrew84zx
G-E wrote: time to hotwire it.... could be the ecu
I'd really like to avoid having to rewire it. I'd hate to have a seperate switch just to turn my fuel pump on. Even tapping into the ignition seems sensless when everything worked just fine as it was.Originally posted by Andrew84zx
MikeZ wrote: I didn't use the zip ties to attach the pump to the frame. I only used a couple of zip ties on the wiring and could see the result, so I wouldn't trust them to hold the actual pump.
Alright, so it turns out it was the plug wiring in the rear hatch. However, I got power to the pump but I still can't get it to fire up. You can hear it prime as soon as I hook up power to it and I go to start it and no fire whatsoever. I don't understand why its not getting fuel to the motor.
I've pulled the fuel line to the motor, no fuel whatsoever. I'm wondering if I got a bad pump?Originally posted by Andrew84zx
cheezmonta wrote: My buddy had that problem when installing a Walbro in his car. There was a relief cap of some sort that wasn't working right so he took it off and the pump worked great.
Having not installed one myself. Anyone know what I'm talking about?Originally posted by Andrew84zx
