Engine stalls with clutch in over 2500 rpm
  • Engine stalls with clutch in over 2500 rpm
    86 turbo 5 speed
    Ok, my idle is at about 750 rpms. My car starts quickly & easily. If I rev the engine & let off it stalls. While driving, if I put the clutch in and just let the engine fall off instead of downshifting the engine stalls. The car stalls more easily when it's hot/fully warmed up. The car starts right back up with no issues. Just that it stalls easily, which is annoying. I have tested my car for boost leaks, which should have also found any vacuum leaks (right?) and I have fixed all boost leaks. I have my throttle cable adjusted as tight as it will go & I put a new OEM throttle cable on my car a couple of months ago. Any ideas????? Thanks.
    378whp 445wtq
    How high will it let you rev? If not over 2,500rpms could be the AFM...
    http://youtube.com/c/zcartube
      I used to experience this issue before I started playing around with the ECU. Do you still have the fuel pump wiring stock?
        TPS.... happens to supras from my experience. Might want to check urs
          300zxt wrote: How high will it let you rev? If not over 2,500rpms could be the AFM...
          Soryy I think I misled you. My car runs perfectly. But it will stall if I put the clutch in at any rev past 2500 rpms. I just want to know why my car stalls if I rev it or clutch in & coast to a stop.
          378whp 445wtq
            So it DOES stall at 2,500rpms? AFM then i'd say!
              Jason84NA2T wrote: I used to experience this issue before I started playing around with the ECU. Do you still have the fuel pump wiring stock?
              I installed the Walbro fuel pump. But that doesn't change the wiring.
              378whp 445wtq
                300zxt wrote: So it DOES stall at 2,500rpms? AFM then i'd say!
                No it revs and runs perfectly. But at anything over 2500 rpms & I put the clutch in it stalls. So if I drive to a light cruising in 3rd gear & then put the clutch in and coast to the light, it stalls. If I sit in my garage & rev the car to say 4000 rpms & then just let off, it stalls.
                378whp 445wtq
                  [quote]mark86t wrote:
                  Originally posted by 300zxt
                  So it DOES stall at 2,500rpms? AFM then i'd say!No it revs and runs perfectly. But at anything over 2500 rpms & I put the clutch in it stalls. So if I drive to a light cruising in 3rd gear & then put the clutch in and coast to the light, it stalls. If I sit in my garage & rev the car to say 4000 rpms & then just let off, it stalls.
                  My Z32 used to do this for a while and a lot of people mention having to put some tape over the intake filter. I'm assuming its to cause some sort of turbulence for the AFM? Mine went away after a few days of driving.
                  545 RWHP & 540 RWTQ
                  VG30ET.com Member
                    My car has done this once after I installed cams and I have been told that it can be fixed by just adjusting the idle a little higher...although my car normally idles at around 600, not 750.
                    2006 Scion tC (Wife Whip)
                      Taris Blue wrote: My car has done this once after I installed cams and I have been told that it can be fixed by just adjusting the idle a little higher...although my car normally idles at around 600, not 750.
                      Since it is a turbo car there is no idle adjustment screw. I tried to increase my idle using the throttle cable. It's as tight as it can be adjusted & the idle never changed. I'm trying the TPS today to see if that changes anything.
                      378whp 445wtq
                        Originally posted by Taris Blue
                        My car has done this once after I installed cams and I have been told that it can be fixed by just adjusting the idle a little higher...although my car normally idles at around 600, not 750.Since it is a turbo car there is no idle adjustment screw. I tried to increase my idle using the throttle cable. It's as tight as it can be adjusted & the idle never changed. I'm trying the TPS today to see if that changes anything.
                        I thought you rotated the tps to adjust the idle? That is what i did...
                        Also, my car HATES to idle at 600, 800 is the best feeling.
                          Well I adjusted the TPS today as per the manual. No change. Still stalls. Gonna remove the rest of the "junk" from the plenum soon, maybe this will help.
                          378whp 445wtq
                          • #14
                            mark86t wrote: I tried to increase my idle using the throttle cable. It's as tight as it can be adjusted & the idle never changed.
                            There is an adjustment screw on the TB itself.It basicaly prevents the
                            butterfly valve from closing completely.You will need an 8mm and a
                            flathead to adjust this screw.
                            This is how you will set your idle with the idle controls removed.
                            imagination is a virtue
                            • #15
                              So did you replace the tps yet?
