Advice needed.
I have owned a 1986 300zx Turbo for around a year now. And would like to say they are by far my favourite Japanese car. Not to mention (at least where im from) absolutely unbeatable in terms of massive value for money. One day I plan on Building The Australian version of the z31, Using an RB30DET... but yeah, that will never happen. And I like the earlier vg30 equally as much.
The car has never ran properly since I have owned it. It has always had a misfire and ran lean under boost. It also Idles high.
I recently Changed the timing belt and installed new stock turbo injectors among other things and noticed that the left hand side cam seemed to have an amount of play before the gear actually revolved the cam. I think its because It has been driven so long misfiring on that head (6th cylinder was not firing).
Anyway although it made a huge difference it still has the underlying leaning out/hesistation. I have put it down to the fact that the previous owner obviously has driven it unkindly etc, and thought that it could really do with a complete rebuild.
Anyway to the point, I need to drive the car, and after looking around have found a VG30E which appears to be out of a Nissan Gloria (Judging by the intake manifold) and have thought of taking the current engine out and installing this engine, bolting the existing turbo exhaust manifolds, intake, oil lines ect to it while the original engine is getting rebuilt.
Now after some research i found that it has been done, being realistic Im not expecting 2000 horsepower out of it, but how does the car drive with a turbocharged NA engine??
I just want it to be reliable untill the other engine is ready.
Thanks for any help.
Oh yeah, just thought Id add Id be running Premium fuel, which is 98 octane. Hopefully it helps with the higher compression.
