COuld be the CAS, but usually when they fail it's an outright failure and not just causing poor running. It's tough to say what it is, maybe your timing belt is off a tooth on one of the cams?
[quote]MachZ wrote:
Stock timing for the year ECU you are using, or a few degrees retarded if you encounter any knock. For instance I never had an issues at stock boost with 17BTDC on a 85T ECU (Which stock is 20BTDC). I was able to run 20BTDC and 12PSI once I intercooled it, but that was at the limit of stock fueling.
[quote]MachZ wrote:
Originally posted by Jason84NA2T
