Thought I would chime in on this.
GT3071R
.78 A/R ATP divided housing
4" inlet
custom oil feed line
stock oil return with ATP adapter
V-band flange
This has got to be the biggest turbo you can fit in the stock location. Seems like everything around it clears by only 1/4".
Note that downpipe is shifted 3/4" to the right to clear.
This turbo is water cooled as well, but I decided not to run lines due to a severe lack of space.
I'm using a Tial gate. I welded in a dividing wall for the inlet pipe for that to keep exhaust flow between banks seperate. The top of this wall protrudes slghtly so it extends into the valve seat of the Tial, but not touching the valve. I suppose you could only drain 1 bank with your gate and not go through all this trouble, but the sound of all 6 cylinders coming out of there cannot be beat. 8)
I haven't driven the car a whole lot so far. I'm still using the stock fuel system and running 14 psi. I CAN tell you there is a lot of torque now! I find myself trying to drift this thing and UPSHIFTING mid-drift. Totally opposite from any other car I've driven. I keep this updated once I get my fuel and tuning sorted out.
GT3071R
4" inlet
V-band flange
