porting stock T3 O2 elbow
  • porting stock T3 O2 elbow
    What is the best dremel attatchment to bore out the openning in the stock T3 exhaust elbow? I need to bore it out a little since my stock housing was bored to fit an O-trim exhaust wheel.Now I need to match the elbow to the new bigger diameter exhaust wheel.
    Any pics?
    Shiro #443
    Use a dremel conical stone grinder.
    1988 SS TURBO BEING RESTORE.
      I used the large grinding stones meant for harder metals, and I remember having to use a lot of them. I forget the part number, but you should be able to find them at home depot.
        Dremel is too slow. Use a Die-grinder with a carbide bit for steel
          took care of it with my die grinder and my air compressor last Saturday.Ate it up like butta.
          Shiro #443
            roastin300 wrote: Dremel is too slow. Use a Die-grinder with a carbide bit for steel
            Agreed, but not everybody has a die grinder and bits for steel. The only burrs I have are for aluminum, and my air compressor is a joke :-(
              I had to stop every few minutes to let the air pressure build back up.Would've been alot faster if my compressor was a little better.
              Shiro #443
