I'm curious- at what RPM's does everyone turbos start spooling up, and what turbo? It's not something I hear much of.
Turbo spooling
Turbo spooling
Tags: None
begin spooling, i.e. boost starts coming onLance 'never-ending 88na2t project' Landry
Stage 3 turbine, stock housing. 60-1 compressor.
Depends on the gear you are in, but it gets 1-2PSI at 1800-2000rpm and steadily builds. This is going off memory but it's something like:
10PSI by 3000rpm
15PSI by 3800rpm
21PSI by 4500rpm
It's a little odd how it spools. Lots of more efficient turbochargers will build boost almost instantly if they are sufficiently over the threshold RPM. I think the larger compressor and small turbine housing has a lot to do with the strange-ish boost response.
