Ok, I'm starting to draw plans and create a budget for my restore project.
This is my drivetrain goal: A reliable (100k miles reliable), streetable, can drive in 90 degree weather on pump gas, 350 wheel horsepower that spools quickly and is attainable with equal to or less than 10 lbs of boost.
This is my plan: I want to keep a T3 sized housings and keep the stock elbow + internal wastegate for my turbo as i already have the CM turbo back setup. I really like the GT3 series ball bearing turbos from garrett but I've never done any custom work before so this is kind of a new thing for me. I plan on doing a MILD cam regrind, heads port + polish as well as a valvejob. I am going to go with a gutted plenum and I'd like to find a good innercooler as well.
My questions are as follows:
What turbos would you recommend that are RELIABLE, will spool quickly, and be relatively effecient at 10 lbs boost? Money really isnt the issue and I'm fairly sure that my goals are modest enough to where anything will fit my budget (variable vanes excluded).
What innercooler would you recommend with these goals in mind?
