Turbo Disassembly
  • Turbo Disassembly
    Is it fairly safe, as far as me fucking up my only two turbos, to take apart the turbo? And is it Ok To combine turbo parts. They are the same T3 turbos.
    http://www.wass.andrevas.net/camera%201088.jpg
    Yes, the only problem you might run into is the bolts into the turbine housing tend to be VERY stuck. The center section can also be very well stuck into the turbine housing as well. all the parts interchange, but if you plan to disassemble the center section (cartridge) be sure you know what you are doing first.
      As to not clutter up the forum:
      Is the turbo engines oil pump of larger size?
        the spring is marginally stiffer creating slightly higher oil pressure
        unless you're pumping a lot of sludge or have a relocation kit it and cooler you should be fine with any of them
          Thank you
