my stock gauge must under read what it is, because even when it shows that it is near 270 (at 250) the overflow tank isn't going nuts or anything
Hose Temp.
300zxt wrote: 12 psi is hardly the motors "razor edge" but more the limit of the stock fuel system and efficiency of the stock turbo..." I don't want to come off sounding butt-hurt, but I really loathe most cressida owners and I'm glad I soiled their platform with a Nissan dinosaur under the hood." - Butter
what i meant by "razors edge" is that would be the point where you could potentially start breaking things on the stock fuel system, and keeping in mind we're talking about my STOCK motor 12 PSI wouldn't be something safe to push on 93 oct. without an intercooler atleast even if you can push the car that much. just 'cause you can stretch something REALLY far doesn't mean you should which all of you probably already know, and AGAIN i mentioned grabbing the hose as a method of getting a GENERAL FUCKING IDEA to how hot the water is going into the motor knowing all well that the water's going to be HOT anyways. but if you have a good working radiator you should be able to grip the radiator hose for atleast 3-6 seconds before releasing your grip due to heat. and i've always been able to do that with my previous motors on my new radiator. but atleast this once READ EVERYTHING i'm trying to point at and not just that i'm trying to test the temperature of the car "redneck style."
craZed wrote: How about running that red z, and then grab its hose.That should give you the idea you are looking for.Originally posted by Andrew84zx
[quote]RedBeauty84ZX wrote:Originally posted by 300zxt12 psi is hardly the motors "razor edge" but more the limit of the stock fuel system and efficiency of the stock turbo...
Its not even near the limits of the stock fuel.
"The stock fuel system can only support roughly 12-14PSI of boost pressure (using a stock T3) before the air to fuel ratio (AFR) rises to an unsafe level."
http://www.redz31.com/turbofaq/turbo.faq.htm
I didn't pull it from my ass...
[quote]300zxt wrote: [quote=RedBeauty84ZX]Originally posted by 300zxt12 psi is hardly the motors "razor edge" but more the limit of the stock fuel system and efficiency of the stock turbo...
WRONG!
I didn't pull it from my ass...Originally posted by Andrew84zx
WRONG!Originally posted by 300zxt
I didn't pull it from my ass..." I don't want to come off sounding butt-hurt, but I really loathe most cressida owners and I'm glad I soiled their platform with a Nissan dinosaur under the hood." - Butter
Morgenstern wrote:My brother ran 15+PSI for a whileOriginally posted by Andrew84zx
Morgenstern wrote:My brother ran 15+PSI for a while" I don't want to come off sounding butt-hurt, but I really loathe most cressida owners and I'm glad I soiled their platform with a Nissan dinosaur under the hood." - Butter
exactly, the stock fuel system (without upping the fuel presure) will not support more than 12 psi without causing damage (wether small or big). you MUST upgrade to a FPR, and up the fuel pressure, and mount a front mount intercooler to boost towards 12-14 psi before making more heat than power. *shrugs*
Jason84NA2T wrote: I challenge you to put a EGT and wideband on and find out exactly how bad running over 14psi can be with a stock fuel system. Regardless, the safe maximum is well below that amount of airflow the T3 turbocharger can manage." I don't want to come off sounding butt-hurt, but I really loathe most cressida owners and I'm glad I soiled their platform with a Nissan dinosaur under the hood." - Butter
