Zach, regardless of compression HEAT IS HEAT! i don't care if you found a way to run a 5.4:1 compression motor and turbocharged it, HEAT IS HEAT! above 10 psi you're on the "razor's edge" and asking for trouble on stock inj., and without a FMIC, or tuning of the FPR. :mrgreen:
Hose Temp.
It could be detonating like hell and you're not hearing it aswell...
Morgenstern wrote: Zach, regardless of compression HEAT IS HEAT! i don't care if you found a way to run a 5.4:1 compression motor and turbocharged it, HEAT IS HEAT! above 10 psi you're on the "razor's edge" and asking for trouble on stock inj., and without a FMIC, or tuning of the FPR. :mrgreen:" I don't want to come off sounding butt-hurt, but I really loathe most cressida owners and I'm glad I soiled their platform with a Nissan dinosaur under the hood." - Butter
300zxt wrote: It could be detonating like hell and you're not hearing it aswell..." I don't want to come off sounding butt-hurt, but I really loathe most cressida owners and I'm glad I soiled their platform with a Nissan dinosaur under the hood." - Butter
Look, I've got an Autometer A/F off my stock Titania sensor and I'm running 12 psi right now and It runs VERY rich under WOT. I can put a video up if no one believes me. I've also had Chuck's wideband on my car and Brent can verify that my car was running full rich under WOT with 93 octane. What's so hard to believe about this?Originally posted by Andrew84zx
RedBeauty84ZX wrote: At 15psi the lambda meter reads full rich through out the RPM range with no tuning. The car has 0 fuel issues and runs just fine.
A couple things you should all understand:
1. A narrowband sensor is a completely useless device for tuning. Take it out and throw it away. It can measure only ratios very close to stoich and hence will always read rich even when the engine is as lean as a 13.0AFR (which is dangerously lean).
2. Even if the engine runs fine and has no detonation at a given AFR, it still may not be considered safe. There are more variables you are looking right over.
RedBeauty84ZX wrote: If the charged air becomes too hot then forcing more air into the engine would be inefficient. The T3 will be in that inefficient state before it can force enough condensed air into the combustion chamber to rival the stock fuel output.
[quote]Jason84NA2T wrote:Originally posted by RedBeauty84ZXAt 15psi the lambda meter reads full rich through out the RPM range with no tuning. The car has 0 fuel issues and runs just fine.
1. A narrowband sensor is a completely useless device for tuning. Take it out and throw it away. It can measure only ratios very close to stoich and hence will always read rich even when the engine is as lean as a 13.0AFR (which is dangerouslyOriginally posted by RedBeauty84ZXlean).
also doesn't the computer run in open loop when under full throtle ignoring what the o2 sensor is saying and just dumping as much fuel as possible therefore always reading rich rich rich when at WOT?85 Z31 6.0 LSX turbo 766whp/792wtq
Morgenstern wrote:also doesn't the computer run in open loop when under full throtle ignoring what the o2 sensor is saying and just dumping as much fuel as possible therefore always reading rich rich rich when at WOT?
I'm not saying that using fuel is a good way to keep your block cool. thats like saying advance your timing a lot to keep your block cool.85 Z31 6.0 LSX turbo 766whp/792wtq
Morgenstern wrote: actually i mentioned nothing of the sort...
edit, sorry that was redbeauty and flawlez
either way I agree that you cant rely on dumping lots of fuel as a method to keep the block cool, but redbeauty and flawlez are saying that its rich as hell when the only reason it says that is cause the computer is saying dump lots of fuel.
this is a little off topic now85 Z31 6.0 LSX turbo 766whp/792wtq
well everyone keeps talking like you can push 10-12 psi without any modifications to your fuel system at all, or adding any source of cooling. i mean sure you CAN do it, but that doesn't mean it's safe. shit i could jump off a 50 ft. cliff into a lake and survive, since most people have done it, but doesn't mean that something can't happen. you know what i'm sayin'??
Jason84NA2T wrote: It can measure only ratios very close to stoich and hence will always read rich even when the engine is as lean as a 13.0AFR (which is dangerously lean).
I've never heard it explained in #s like that.
It's always hearsayers wanting to flame someone saying they
aren't precise without actually saying how far off they actually are.Attached Filesimagination is a virtue
