I now have the dyno data and will start formatting it to complete my plenum page when I get time. Three pulls were done on each plenum, and as each one got more heat into it after a pull, power went down 7-10hp as expected. This is something you really can't avoid, except for giving the same amount of time between pulls to allow the plenum (and IC) to cool slightly. The plenums were not run stone cold on the first pull, the engine was warmed for a little bit before we ran them, still they get heat in them quickly, so even 5 mins between pulls would not restore them to ambient temp. This was also as expected, so I will average the best and worst of the 3 pulls on each for comparison. For most of them this was the first and third pull.
All of the gutted stock plenums have similar characteristics and made very similar power figures. The stock plenum flat out sucks.
Below is an image of the end result, showing gains of (one of) the modified plenums over stock. I'm not telling which gutted design performed "better" until the page is done (so you can read it there). As I said; there is, overall, only a very small difference between each of the gutted plenums.
Below is a pull with the stock throttle body and the 240SX throttle body. This confirms the flow bench findings that the 60mm throttle body is a completely useless waste of money on an un-modified plenum even if you port the entry to match. I can't believe so many people wasted their time on this one with no flowbench or dyno evidence for so long. Behold parrot power! Stock is the solid line and 60mm is the dashed. We gave it some extra cooldown time while swapping the throttle body, so it should have made a couple more hp just from that; oh well.
In a small side note, I want to throw this out there for debate. I've read some people's postings on other forums saying things along the lines of bigger is better, and they put big throttle bodies on little engines, so why not on ours? This is a simple tailoring of the throttle characteristics of the engine in question, and not by any means a measure of actual performance "design" or horsepower expectations of the engine. Throttle response and part-throttle characteristics change greatly with the size of the throttle plate (less movement + larger plate = more airflow... derrrrrp).
