i guess i missed something?
Sneak peek at gutted plenum dyno results.
being new to the z scene i have to hand it to you guys, as a community you seem to have a lot of time into research. i own a 86 maxima, a 84 n/a Z, and a 99 altima and for the most part most of the communities i've seen are full of hot air rather than straight facts and dyno charts. i want to personaly thank jason for his site and for the work he has put into this communityDD:
86 Black Turbo 5spd
The Fallen:
Parting Currently:
Garage Sale
MADMIKE wrote: being new to the z scene i have to hand it to you guys, as a community you seem to have a lot of time into research. i own a 86 maxima, a 84 n/a Z, and a 99 altima and for the most part most of the communities i've seen are full of hot air rather than straight facts and dyno charts. i want to personaly thank jason for his site and for the work he has put into this communityJust stand back and throw money.
Performance costs money.
crowbar wrote: Does anyone have a completely stock 'Nissan' dyno graph that can be compared to this? Either NA or turbo?
Scroll down for norcalZman's car, about as close to stock as I would have on there.
The gutted plenum, stock plenum and stock plenum with 60mm TB (in Jason's testing) all produce the same HP from 4000-5000 (roughly)?
I would expect the gutted plenum to actually shine in this RPM range. They (gutted plenums) do extend the RPM/HP range higher past 5000 RPM. They also seem to have a very nice torque benefit lower than 4000 RPM.
Is there corresponding AFR data also? boost level? MAF readings, etc?Try not to be a Yahoo
crowbar wrote: Is there corresponding AFR data also? boost level? MAF readings, etc?
AFR is the usual high 11's for all areas in boost, which is stable at ~10.5PSI where I tested all the plenums.
