I have a small problem in my car..
Everything works fine before i did run TopSpeed run in airport.
1800m (1.11846815 miles) with 202kmh (125.516981 mph) topspeed. Pedal to the metal whole run.
Few month after this i have change sparkslugs to one step colder and big K&N filter. Stock in other ways..
Dynosheet. I'm missing 10HP and i have 20Nm torque than stock. rear muffler was damaged (no internal parts.. 107db sound :shock: ). Timing was off 3-5 degree.. (Stock 228HP/5400RPM, 326Nm/3600RPM)
After that every once an while i get small problem. Might be one a day / week / month. Maybe few times in summer..
No matter if i'm running in city for low cruise or higher speed on freeway.
Car starts to put Black smoke like diesel engine on dragrace ( :lol: ). If i touch gas pedal it smokes more and rpm's don't go much up.
No boost.. no matter how i try i can't get boost.
One time friend of mine say it sounds like i'm runnig in 5 cyl. not 6.
(Sparkplugs were changed after first time this happened)
If i just cruise gently problem goes away ion few min. and if i stop on busstop + few min. waiting everything works well after that.
Few times problem have gone away with pumping gas pedal and force to boosting
I have had this problem hence summer 2004 when i did that topspeed run. I drive my car maybe 3000km/year (1 864.11358 miles) in 4-5month @ Summer.
Rare problem and no one really can tell me where should i start to find this problem.
I have think it might be injector that stuck in 100% open.
I'm not good and mechanic and engine problems.. I have spare 88T engine in pieces and getting new parts for it. I just hope i could find what is the problem in my org. engine.
