this is how you modify your motor mount bracket to fit on the turbo crossmember and mounting spots on the block. I used a hacksaw and wheel grinder to shave away enough material to get the motor mount to clear the turbo oil supply.
just shave away material so that it will clear the oil fitting.
without the motor mount:
with the motor mount:
