You nailed it regarding the turbo coolant lines. It does help to stabilize the temps. the turbo can reach. It does also help keep the oil temp on the downside of too hot.
*You honestly haven't 1 single thing to worry about with na2t conversions on a stock T3...it is being made out to be scarier than it is. Just follow the key tips everyone has offered.
*In regards to the install./removal of the engine:
-The exhaust manifolds, turbo and o2 elbow, should all be installed before dropping the engine back in. How it comes out is how it goes back in.
~The downpipe will go back on after the engine is mounted up.(you'll see)
**Looks like you have it all thought out and covered.
