84z31 wrote: i've been thinking about doing the same thing only different. ops:
how come you made the back portion so small. the larger the plenuim the better low end you are supposed to have. and the longer the runners the better top end.
i was actually trying to design something with a larger plenuim area and then making the runners longer.
the penis is interesting. NSFW warning is probably needed. :wink:
His design is correct in shape, smaller at blocked end, as the cylinder closest to the inlet can be down on airflow up to ~5%. While the cyl at the blocked off end will be up ~5%. Detuned engines no problem, it becomes an issue with increased HP
