Just to reiterate the fact that EBay Turbos are complete garbage, at the place I do some side work a customer brought in his 5.0L Fox body for a big build and yesterday he brought me this Turbo so I could get started on the Manifolds and I said it was garbage and that I would never put it on his car well long story short I had to prove it to him because he is fucking clueless
On these first couple pictures, I inverted the colors to make the problem extremely visible
Now this gasket is not only entirely too thin, but its also about an easy inch too large, as well as split. With a 76mm wheel spinning at 80,000rpm... you can see why that could become a problem pretty quickly.
Another thing i noticed was on the backplate... its surface is rough and unmachined, as you can see in this next pic...
Just thought I would share
