I'm replacing all the exhuast studs on the beater while I do the na to turbo swap. Luckly, none of them broke off. I guess having an engine with only 70K on it helps.
Should I use anti-seize compound or something on the studs before I start putting the newer ones in?
Side note: It is sooooo much easier to work on a Z when EVERYTHING has been removed from the engine bay that is not needed to keep it running and legal on the streets. I have sooooo much room to turn a wrech its almost scary.
